S scshost New Member Aug 24, 2007 #1 How can I transfer my domain to WHM so i can control it from there?
S scshost New Member Aug 25, 2007 #3 i have a domain thats at namesco, i cant use it in WHM how can i make it so it is usable in WHM?
K khiltd New Member Aug 25, 2007 #5 I'm not sure an unmanaged VPS is the best solution for you right now.
Skyview Member Aug 25, 2007 #6 khiltd said: I'm not sure an unmanaged VPS is the best solution for you right now. Click to expand... sounds like good advice to me
S scshost New Member Aug 25, 2007 #7 lol who do i get to manage it and how much will it cost? i know how to park it, i just change the nameservers just need to know what the nameservers are?
M magic New Member Aug 25, 2007 #8 you should put in a support ticket if you are having problems getting your server set up. they will help you do the transfer if needed.
