T tinat New Member Jul 24, 2008 #1 Is it possible to use rsync with reseller hosting? I'd like to use it with cron to make offsite backups.
P ppc Moderator Jul 24, 2008 #2 tinat said: Is it possible to use rsync with reseller hosting? I'd like to use it with cron to make offsite backups. Click to expand... rsync should be installed on the server but that would only work if you have SSH access. I'm pretty sure the Reseller accounts do not have SSH access. You would need a VPS for that.
E echizen New Member Nov 1, 2011 #4 tinat said: Is it possible to use rsync with reseller hosting? I'd like to use it with cron to make offsite backups. Click to expand... why not create it from cpanel cron? :s
A amy66 Member Apr 21, 2012 #5 echizen said: why not create it from cpanel cron? :s [Broken External Image]:http://tiny.cc/jr5nax Click to expand... Is it easier that way? Last edited: Feb 2, 2014
